Concept 2 Indoor Rower Handle Replacement Kit - Part number 1931
Part number: 1931
Replacement handle kit that allows you to retrofit manufactuerer grade indoor rower handles. This handle is 19Inches long with overmolded grips and features an ergonomic 10-degree bend that better simulates arm position of on water rowing and provides a more comfortable position throughout the rowing stroke.
Used on the Following Models Listed Below.
Concept II-
Model D Indoor Rower - After 07-19-12 - Black
Model D Indoor Rower - After 07-19-12 - Light Gray
Model D Indoor Rower - Before 07-31-2006
Model D Indoor Rower - Between 07-31-06 & 07-19-12 - Light Blue Gray
Model E
Concept II-
Model E
More from Concept 2
Concept 2 Indoor Rower Chain Axle Replacement Kit - Part Number 1915
Part number: 1915
Concept 2 Indoor Rower Shock Cord Replacement - Part Number 1731
Part number: 1731
Concept 2 Indoor Rower Thirty Inch Footstrap Replacement - Part Number 1517
Part number: 1517
Concept 2 Indoor Rower Twenty-Four Inch Footstrap Replacement - Part number 1501
Part number: 1501
